talaveracali escribió:Que yo fabrico Axe,por lo menos el after save,le añadimos feromonas de esas pa que las chicas se vuelvan locas,JI JI JI JI..........
La formula es confidencial,siento no poderos decir mas.
AJJAJAJA, claro, la fórmula es secreta pero tu la sabes, no?
Marc escribió:Lo más frecuente es que oigas: el culo es para cagar....
Error 401 Unauthorized
She is looking for some encryption key from the client and is not getting it. Also, wrong password may have been entered. Try it again, paying close attention to case sensitivity.
Error 403 Forbidden/Access Denied
Similar to 401; special permission needed to access the site. Other times you may not have the proper permissions set up, or the site's administrator just doesn't want you to be able to access the site.
Error 408 Request Timeout
Client stopped the request before the server finished retrieving it. Usually occurs when servers are slow or file sizes are large.
Error 500 Internal Error
Couldn't retrieve it because of configuration problems. Contact site administrator.
Error 501 Not Implemented
She doesn't support the requested feature.
Error 502 Service Temporarily Overloaded
Server congestion; too many connections; high traffic. Keep trying until you get it.
Error 503 Service Unavailable
Server busy, site may have moved ,or you lost your connection.
TELVM escribió:Una cosa es el colector de admisión, y otra el de escape .
Mal asunto confundirlos, Maese Tropic, alguna se puede enfadar seriamente . Aunque te hayas rociado con Axe .
Mea culpa. me habia parecido un colector de escape la foto que habias puesto, en serio...
Por su bien, mejor que no me equivoque de colector...
¿Qué tiene en común el lenguaje de las mujeres y los servidores web?
400 Bad Request Dímelo con flores
401 Unathorized Estoy casada
402 Payment Required Son 10.000 y la cama
403 Forbidden/Access Required ZZZAAASS! (Bofetón)
404 Not found He quedado con las amigas
405 Method Not Allowed No, por detrás no...
406 Method Not Acceptable ...y en la boca menos!!
407 Proxy Auth. Required Lo hablaré con mi madre
408 Request Timeout ¿Sabes cuánto hace que no me llamas?
409 Conflict ¿Quien era ESA?
410 Document Removed Quiero el D-I-V-O-R-C-I-O
411 Lenght Required ¿A eso llamas "pedazo polla"?
412 Precondition Failed ¿Que no has traido condones?
413 Request Entity Too Large Eso no me va a caber ahí dentro
414 Request URL Too Large Eso tampoco me va a caber ahí dentro
415 Unsupported Media Type A cuatro patas no me gusta
500 Internal Server Error Tengo la regla
501 Not Implemented Nunca haría *eso*
502 Bad Gateway ... y por ahí, menos todavía
503 Service Unavailable Me duele la cabeza
504 Gateway Timeout ¿Ya está?....... ;-DD
