Un Calibra impecable en ebay, toda una rareza
- ministrillo
http://www.ebay.es/itm/Calibra-V6-with- ... 610wt_1396
Merece la pena verlo porque lo tiene de fabula el ingles....
Hello,
I am selling my much loved Calibra V6 last edition with 103.500 miles. This car has had serious time and money spent on it after being stripped to a rolling shell in 01/2010- 6/10, all modifications have been carried out professionally and to a very high standard, the car has been wax-oiled in all the usual rust prone places and other areas stone chipped, stainless screws/washers/nuts/bolts fitted where safe to, all new seals, bushes, ball joints. The car has been completely resparyed. When bought, the car had no rust on it and remains rust free. I have only put 13.000 miles on the clock since project completion, 9.000 miles when traveling Europe last year. I have 10k of receipts. The car comes with the usual v6 full spec including A/C. I have three keys, two chipped with integral lights the other is only for entry. All electronic features work and the car has never been involved in an accident. All custom extras listed below. Thank you for looking.
External;
Full respray (Jet black) Colour coded roof rails, mouldings and door handles (passenger side de-locked), Rieger side skirts and front valance, Irmscher rear spoiler (with brake light (new) and rear panel. Also has xennon dip and full beam conversion. All the window seals have been replaced on the doors, both drip mouldings that run along the A to C posts including front windscreen surround have been replaced, has parking sensors (2x front 4x rear) Stainless "Calibra" engraved kick sills, Opel Badging, under-bonnet light.
Interior;
Vectra 2000 LCD tacho (fully functional with check control and has been modified to show T/C and Airbags warning lights), has engine/gearbox oil temp gauges fitted into the old oil/amp facia (Factory finish look), Vectra ST200 carbon steering wheel (bought new), audio controls, Cruse control, variable wiper speed/on board computer control stalk, driver and passenger floor well lights (using OE calibra parts), Chrome door handles, Bi-passenger electric window switch fitted onto passenger door, 6x9 rear speakers in place of the original speakers hidden and non visible.
Running gear;
F28 6 speed gearbox with Quaife LSD and new custom stainless steel selecter-fork, Courtenay lightened flywheel, uprated clutch, Uprated anti roll bar bushes, Eibach and Bilstein suspension, 308mm front brakes (new callipers and sliders), Goodridge brake lines, Courtenay Sport custom grooved discs front and rear, Yellow Stuff break pads front and rear, Antera 17' alloy wheels, Toyo Proxies T1R 215/45/17 tires and brake disc cooling ducts and locking wheel bolts.
Mechanical;
X25XE V6 with Ram-cold air feed, Courtenay re-worked air-box, Courtenay Sport Air Filter, Courtenay enlarged Throttle body, 5 Bar fuel reg, new ignition amplifier, Magnicor Leads, and NGK Iridium spark plugs.
The car has also had new; crank sensor, 2x knock sensors, air mass meter, air intake temp sensor, ECU temp sensor, gauge temp sensor, both gearshift and handbrake gaters, all the door and bumper moulding have been replaced with new, the F28 gear linkage has been reconditioned with new parts, the gearbox has had all new seals and gaskets and stainless selector fork. New suspension bushes, dampner's, wishbones, factory heavy duty black cloth floor mats (front and rear), new A/C compressor, new bumper support brackets including much much more. This car has pretty much had all parts replaced with new and OE where possible.
The leather interior is in very good condition, only minor rubbing on the drivers seat bolster.
BAD BITS*****
Forth gear crunches and a bearing on the input shaft needs replacing other than that the box is quiet. The A/C Condenser (radiator) has failed. I have bought a new condenser and new dryer which I shall include in the sale. Both door cards have 'lifted' as they usually do. Lastly, there are some non-noticable stone chips on the front bumper from motorway driving but I touch them in whenever they appear. No other problems to report at time of advertising the car.
The car really does drive well having driven to the northern Norway and back problem free. Genuine reason for selling;- I am leaving to work abroad for an unknown period and, I have nowhere to store the car meanwhile.
Please note; numberplate is not included in the sale.
Hello,
External;
Interior;
Running gear;
Mechanical;
BAD BITS*****
Opel Calibra 2.5 V6 24V C25XE
- korvo01
Re: Un Calibra impecable en ebay, toda una rareza
Muy bonito! Me interrogo si el volante del Vectra ST200 es plug and play
mmmm... habra que preguntar al vendedor ...korvo01 escribió:Muy bonito! Me interrogo si el volante del Vectra ST200 es plug and play![]()
Restyling exterior en proceso
¡Dios mio!
¡Que preciosidad! Hay que decir que el inglés tiene un gusto exquisito, parece fabricado en 2005 de lo bien que está y con los 4 toques que le ha puesto, lo ha dejado muy bonito, mas que nada hablo del interior, el toque de los neones blancos con la moqueta beix
Subviraje: el coche se va del morro te sales de la carretera, te chocas con un árbol y mueres.
Sobreviraje: el coche se va del culo, trompea, te sales de la carretera, te chocas con un árbol y mueres.
Así que es mejor el sobreviraje porque no ves el árbol que te va a matar.
- villacampa-19
Está de 10, increíble. Un gozo debe ser viajar con ese coche.
Sobretodo me gustan las estriberas de las puertas que pone "Calibra", ¿Alguien sabe donde conseguirlas?.
En esta espécie de EPC online sale, según esto, si vas a la pelo y no está fuera de producción, te lo tienen que vender ahívillacampa-19 escribió:Está de 10, increíble. Un gozo debe ser viajar con ese coche.
http://opeloem.com/opel/calibra_1989_19 ... ll_i_line/
Pero lo dudo, seguro que te miran con cara rara
En todo caso, en ebay seguro que están, pero sabiendo que se fabricaron originales, yo intentaría conseguirlas originales antes que cualquiera pirata...
EDITO: Parece ser que olvidé poner el enlace...
Última edición por wirlebenautos el Jue, 22 Mar 2012, 11:37, editado 1 vez en total.
- korvo01
Yo las tengovillacampa-19 escribió:Está de 10, increíble. Un gozo debe ser viajar con ese coche.
Yo quiero las estriberas tambien!! jaja
Una preciosidad sin duda, lástima que tenga el volante al otro lado, porque no es caro para nada.
- villacampa-19
korvo01 escribió:Yo las tengovillacampa-19 escribió:Está de 10, increíble. Un gozo debe ser viajar con ese coche.
Un saludo.! No las compre en la pelo, ya no las tenian; las mias fueran compradas en una tienda especializada en piezas auto.
¿Nombre de la susodicha tienda?
- korvo01
No se si aun los encuentran, pero tendrias que venir a Portugal
Tomasport escribió:Marcador digital?????
Es un placer volver a saber de ti ministrillo
Este Calibra es desde luego una pieza rara y en muy buen estado, (esos relojillos en negro de Vdo nunca lo había visto, es muy posible que sean los primeros que se montaron y de los que hubo muy pocos).
muy bonito, una pregunta, se baja la ventana desde el boton de la puerta? :S
Calibra irmscher ... viewtopic.php?f=6&t=24773&start=20
Ya hay foreros que lo han hecho creojony escribió:muy bonito, una pregunta, se baja la ventana desde el boton de la puerta? :S
Iñigo_25 escribió:Ya hay foreros que lo han hecho creojony escribió:muy bonito, una pregunta, se baja la ventana desde el boton de la puerta? :S
Y además hicieron un BRICO, relativamente facil, además los botones tmb se encuentran facilmente, creo que en corsas, pero a mi me gusta eso de que la gente no sepa donde están los botones, le da un toque noventero al calibra que a mi me gusta...
ajaja eso es verdad , ami me gusta cuando empiezan a buscar el botón de donde se abren las ventanas , para mi es mas comodo donde estan situada la botonera.
Luego tambien llevo el portacintas que la gente se keda flipando , dicen pues vaya relikia q fue esto en su epoca..
Y ya ni te ablo cuando empiezan a mover la mano pa intentar abrir la puerta y no pueden
Desgraciadamente Calibras como esos se han desguazado unos cuantos y de algunos se han vendido piezas aqui en el foro. Una pena que tengan el volante en el lado equivocado sino... anda que no hay calibras bien guapos en UK y a precios mas que razonables.
¿esas estriberas eran originales?
Unas identicas a esas me estan esperando en casa de un colega, las tuve en la mano, las pose para pillar otra cosa y al final alli se quedaron
, cuando vuelva por alli me las voi a traer para casa, quiza se las monte al 8v
