Bueno tras ardua labor detectivesca 'siguiendo las pistas' y haciéndole cosquillas con el tester a la 357 Magnum esto es lo que hay:
--> DB37 pin 1 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 2 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 3 --> ·················································
--> DB37 pin 4 --> ·················································
--> DB37 pin 5 --> ·················································
--> DB37 pin 6 --> ·················································
--> DB37 pin 7 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 8 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 9 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 10 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 11 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 12 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 13 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 14 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 15 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 16 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 17 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 18 --> ·················································
--> DB37 pin 19 --> Miata pin 2A/2B y 2C/2D --> GROUND JC-03 y JC-02
--> DB37 pin 20 --> Miata pin 2P -->
IAT
--> DB37 pin 21 --> Miata pin 2Q -->
CTS
--> JS2 --
(cable 8 )--> SPR2 (CANL) --> DB37 pin 27 --> Miata pin 1H --> IGNITOR SIGNAL 2 (Spark B)
--> DB37 pin 22 --> ·················································
--> DB37 pin 23 --> Miata pin 2N --> OXYGEN SENSOR
--> DB37 pin 24 --> Miata pin 2E -->
CRANK ANGLE SENSOR 1 (RPM)
--> Pin 11 (PTC4) de la CPU U14 --
(cable 4)--> IAC1A --> DB37 pin 25 --> Miata pin 2G --> CRANK ANGLE SENSOR 2 (TDC)
--> DB37 pin 26--> ·················································
--> DB37 pin 27--> ·················································
--> DB37 pin 28 --> Miata pin 1B -->
+12V (KEY ON)
--> DB37 pin 29 --> ················································
--> DB37 pin 30 --> Miata pin 2W -->
IDLE SPEED CONTROL
--> DB37 pin 31 --> ················································
--> DB37 pin 32 --> Miata pin 2U -->
INJECTORS 1 & 3
--> DB37 pin 33 --> Miata pin 2U -->
INJECTORS 1 & 3
--> DB37 pin 34 --> Miata pin 2V -->
INJECTORS 2 & 4
--> DB37 pin 35 --> Miata pin 2V -->
INJECTORS 2 & 4
--> PAD3 --
(cable 1)--> Q16 pin central --> DB37 pin 36 --> Miata pin 1G -->
IGNITOR SIGNAL 1 (Spark A)
--> DB37 pin 37 --> Miata pin 1C -->
FUEL PUMP
(P.S. T.P.S.: Ni en el Miata se le hacía, ni en el Misil se le va a hacer, puto caso al TPS. Rulando a MAP es peso muerto.)
