[INFOX] # Catálogo de Buenas Ideas DIY Autospeed #
bmanzanareso
Mensaje por bmanzanareso »
Supongo que no os enseñara nada que no sepais, pero os subo el estudio que se hizo en su dia para el calibra ITC
http://www.megaupload.com/?d=DIGEFLKA
Re: [INFOX] # Catálogo de Buenas Ideas DIY Autospeed #
Ah como me gustaría tomarme unas cervezas y rumiar herejías con el aussie de Autospeed.
http://autospeed.com/cms/A_110403/artic ... larArticle
"When I was a kid in the mid Seventies, oil was going to run out before the year 2000 ... ... That idea now looks like madness. Equally, those who suggest that we will be living in an oil-less world within our lifetimes are probably wrong."
"Here in Australia, the local current Commodores and Falcons are just ridiculously enormous – massively heavy, very unwieldy and just so much larger than is necessary. It’s "mine’s bigger than yours"
(aka "alto y poderoso" :) ) gone absolutely crazy.
It is unarguable that large cars are more difficult to stop, more difficult to accelerate, more difficult to corner, and more difficult from which to gain good fuel consumption. "
"It’s all achievable and straightforward and justifiable; it just needs the strength of mind to ignore what bogan mates say ..."
primero, los enlaces ya no van, buscando por google, puede ser esta la web de autospeed?:
http://origin.autospeed.com/
TELVM escribió: CAUDALÍMETRO
Airflow Meter Bypass I
Airflow Meter Bypass II
segundo, respecto a esto, cambiando inyectores (o aumentando presion de gasolina) en el mismo porcentaje que se aumentase el caudal de aire creo que colaria para engañara la ecu :-k
